1. Neo Wedge T4 2. Neo Wedge T5 3. Neo Wedge T4If you're planning on using LEDs, SuperBrightLeds.com has them. I just did it, they drop right in, although the plastic base is a bit softer than the stock. You'll want to use some pliers or a small screwdriver to gently lock them into place. If replacing all lamps with LEDs, this is what you'll need: Temp Pod (Right): 2x 5mm NEO5-x lamps 1x 3mm NEO3-x lamps Lighting Pod (Left): 5x 4mm NEO4-x lamps
